1987 4.3 omc alignment
jjburru
I have a 87 4.3 omc I just replace the coupler and gimble bearing,and try to use alignment tooll and the back part of the motor has to come up a quarter inch,somebody has been in this motor before i have,apparently the stern drive has been replace and motor.Is there washer suppose to be under neath the back motor mounts before the motor goes in or something,cause the back motor mounts are stationary.
Re: 87 4.3 omc alignment
Maybe this exploded pic will help to see if you are missing anything?
40 0912814 WASHER, Mount
15 0983932 REAR MOUNT
22 0912889 WASHER
21 0911776 NUT
20 0911778 WASHER
19 0313623 LOCKNUT, Rear mount
looks like everything thanks for picture could it be that the rear mounts are worn need replacing the motor is far as it will let it go down and still need quarter inch in the back to go up
The front is far as it will go down,and where the motor sit it is made out of some plastic material.Could it be the back motor mounts worn out?
