1987 25hp wonbt start
poncho52378
"Bought used boat. When put u
"Bought used boat. When put up last year, the boat would only run on half choke. I rebuilt the carborator and it still will not start. It has compression and there is a spark."
"I have an older, (maybe 1
"I have an older, (maybe 1985) 25hp mariner that when starting, fuel squirts out of the top of the carb. Someone suggested that this is a vent and the float is probably stuck allowing the bowl to overfill. Any comments and/or suggestions?"
If it set up up=in a stall unc
If it set up up=in a stall uncovered a dirtdobber may have got in the reed block through the carb. Have seen it happen.
