Hi,
I have a 1987, 25hp, two stroke Mariner outboard attached to the back of a 22ft inland cruiser.
I recently took the boat out and was running the outboard at about 3/4 revs and after about 10 minutes the engine began to pump out quite a lot of steam. I cut the engine and used my back up to get the boat back to it's mooring. I then checked and replaced the impeller (which was in good condition) and change the thermostat which was obviously old and corroded.
When complete I took the boat out and it seemed ok, I was on the boat again this weekend and took her out and I ran the engine at half power for about an hour and a half with no problem running at about 5 knots, there was a very occasional puff of steam, but nothing more than you would expect from splashes on hot parts.
On the way back to the mooring, I decided to test the engine again at higher revs feeling confident the repair had worked and with a couple of minutes the steam started coming from the engine again, not as bad as previously but it was still noticeable. I cut the engine power right back for the short distance back and the engine ran fine, didn't appear to be overheating but still pumped out a bit of steam.
Does anybody have any ideas or any suggestions as to what the problem may be? Or is an amount of steam normal in these engines? I have checked the water intake and it is clear and free from blockages.
The engine starts on the key, runs smoothly and is powerful but I am concerned it is going to seize up if there is a underlying problem with it.
Steve
Steve
