monkey_butler
"I am working on a 1987 200HP
"I am working on a 1987 200HP that I that I just got and before I attempted to crank it I noticed that the carbs were not closing fully. I found that they were being held open by the oil pump linkage. I have another motor that I compared the throw of the oil pump arm against and this one has much less range.
I can tell you that it is not a linkage adjustment problem, it is that the pump arm isn't swing far enough back to the closed or idle position. It doesn't look like there has been a wrench on the mounting pump bolts so I'm wondering if someone may have removed and reinstalled the arm incorrectly or if there is sometning internal on the pump that could cause this.
Any ideas?"
Any ideas?"
