"I am in Harlingen Tx, trying to help a friend. He has a 150 hp Mercury Outboard about a 1987. Motor has not been used very much and has 150 psi compression. The problem is it will come up on plane once. Then rpm drops back to 3000 and will not rev up a again. The motor just flutters. Remove plugs wire and none seen to be dead. All get hot and don't look fouled. Tank has been remove emptied and flushed. Fuel pump repaired. Carburetors removed and cleaned. Nothing was ever found in fuel system.
He then took it to a Mercury dealer and the Dealer replaced the switch box and oil sensor and said it was fixed. The boat did the same thing the next time he put it in the water. On plane once and then flutters. Sounds like it my be running against a rpm limiter. Good water stream out weep hole. Any suggestion would be appreciated."
