1987 120hp J120TLCU charging system and tach
smcc59
Hello,
I picked up a 1987 120 hp looper. The previous owner was a tinkerer and this thing has a few problems left in it.
The charging system is not working. When it runs at idle the volt meter is all over the place. When I give it a little gas, the meter settles out. The tach reads higher than what it runs at and is not even close to accurate. I changed out the voltage regulator/rectifier with a known good one. The tach worked, but the charging system is still out. Any help is appreciated.
Re: 1987 J120TLCU charging system and tach
Hello,
What are you using to ascertain your charging system is NOT working? Tester? Gauge?
Using a multi meter set to DC on the battery + and - pole with a slow increase of rpms you will see the volts increased from 12V DC to 13/14 VDC .....
Here you go Bud ..
http://forums.iboats.com/showthread.php?t=190636
