Yamahadude
Alright so I have a 1986 pro v 150 on a 90s model procraft bass boat. The trouble I'm having is the boat runs fine on the muffs sitting the yard give it gas seems to do fine with the arm I never put it in gear and revved it.. But on the water it also idles fine but once you get to moving to put it under a load it doesn't rev past around 2-3 rpms. It will not get up on plane it's not really bogging down or surging just reaches that rpm and will not go anymore.
I cleaned the carbs, changed the fuel lines, fuel filter, new primer bowl, new plugs. I checked it's getting spark. took it out. It's doing the samn thing it did before. I even tried a different prop didn't change anything. I did notice the boat got low on gas and hit a wave it would take off to wide open throttle but died right back off again.
Is there any suggestions what else could be done. possobly just rebuild the carbs instead of trying to clean them? Possibly stator? Any suggestion or even knowing what it is would be helpful.
Thanks a lot in advance!!
