mcconvillejo
Hi,
I'm new to repairing outboards but i just got my 75 hp mercury working after rebuilding carbs and changing a faulty Stator and Trigger.
About a week ago I took the lower linkage off, checked the water pump and changed the gear oil.
I took it to the launch today and it started up and idled fine. When i put it into gear the prop wasn't spinning, the boat was revving fine. The boat was operating as if it's in neutral and the prop wasn't moving.
I went back today removed and reattached the prop and lower linkage. I noticed that the prop spins freely with my hand when the boat is in gear. I get the same results when in neutral. Prop spins freely both clockwise and counter clockwise.
Is this a symptom of a boat not going into gear?
I should also note that when i spin the flywheel by hand the prop turns in the proper direction.
Again I have a 1986 Mercury 75HP S/N:0B107122
Thank you in advance for your help!
