After changing the water pump I have found that my motor doesn't engage the tilt-lock in reverse, or in any gear for that matter. I know this is likely something to do with the ramp-like cam in the lower unit. I pulled the lower unit off and found that the cam does not seem to be in the right position. The ramp is pretty much at the bottom in neutral, so the lock is not engaging in any gear. I know you can turn the shaft to go through the gears, but I don't understand how to possibly get this cam to align correctly to the required gear without removing it from the splined shaft?(Is this even possible?) Here is a picture of the cam with the gearbox in neutral. I hope what I'm trying to describe makes sense, any help is appreciated, thank you!
Picture:
https://drive.google.com/file/d/12G--q4EZu-d-2UBiMizFhdz9-V5E3xdX/view?usp=sharing
Picture:
