[FONT="]1986 Mercury 25HP XD
[/FONT]
[FONT="]Can only get it to momentarily hit one time when I first start to work on it, then nothing, not even with ether/spraying fuel in carb[/FONT]
[FONT="]
[/FONT]
[FONT="]Plugs seem to be dry[/FONT]
[FONT="]
[/FONT]
[FONT="]Compression Cold is 98 on both cylinders/no leaking[/FONT]
[FONT="]Just replaced both crank seals and wear sleeve[/FONT]
[FONT="]Has Spark - Just Replaced the Stator because I thought spark might be weak/really good spark now[/FONT]
[FONT="]Trigger resistance seems normal at 780[/FONT]
[FONT="]Replaced one coil[/FONT]
[FONT="]Flywheel Key is intact[/FONT]
[FONT="]Carb Rebuilt[/FONT]
[FONT="]Replaced both exhaust manifold gaskets to fix water leak into lower cylinder[/FONT]
[FONT="]New Fuel tank, Lines, Filter[/FONT]
[FONT="]
[/FONT]
[FONT="]Any ideas?[/FONT]
[FONT="]Thank you in advance[/FONT]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
