I have an '86 Mercury 50 hp 2 stroke, which had been sitting up for about 15 yrs. I recently had a major tune-up, which involved the following:
100 hour service/Tune-up/Impeller maintenance
Removed Auto-blend (doing 50:1 pre-mix now)
Fuel pump diaphragm kit
Carbs removed and cleaned
New Fuel line
Flushed fuel tank
Water pump kit
Repaired wiring from the switch box
Spark plugs
With all of that done, I'm having problems with the engine stalling out when I put it in gear. It's not stranded me yet, but it makes it very difficult to maneuver around a busy launch dock.
It cold starts fine, idles fine (about 1100 rpm) and gets on plane just fine. It will do about 30 mph @ 5500 rpm, no problem.
However, if I've been fishing in a cove for a bit, then start it up to move to another location, it will stall when I push it into gear. Once this stall happens, it doesn't want to start up again, smells like I flooded it and requires that I let it sit for a few minutes before trying again.
I've been able to workaround this by pushing the throttle up very quickly to get going, then pull it back to a slower speed (5 mph speed limit in the coves and of course around the dock).
Any feedback will be greatly appreciated!
New Fuel line
Flushed fuel tank
Water pump kit
Spark plugs
