1986 Johnson VRO 60HP 3 CYL dies/stalls quickly under acceleration.....
awallburg
Hello All,
First post so I apologize if I forget to mention a necessary item.
I recently Purchased a 1988 Bass Tracker with the aforementioned outboard and have had it on the water only 6 times. The Previous owner took EXTREME care of the thing, and i mean VERY GOOD care, he was an older retired VET who couldnt manage it anymore so I know it was cared for and garage kept, he had records, provided me with oils, lubes etc that he had left over if that tells you anything, he also provided me with the service manual for motor.....
So here is what happened, on my third trip out I literally was on my way back to dock to go home and ran out of gas.... Used the Trolling motor to get it the last 1/4 mile there.
Next Trip out I filled it up, and for some reason I closed the vent tight on the gas tank, I saw it, was not sure what it was and closed it up..... Launched the boat got it started from cold start with a little choke and had no issues, was headed to a camping site a short distance away and it was close to dark so I didnt go far and didnt open it up TOO MUCH.....
The next morning when We were out and about I attempted to open it up finally and it would just die, started fine.... I would put it in gear, throttle up a bit and it dies again, rinse wash and repeat..... I was able to get it throttled up just enough to get around.... Barely past no wake speed... anything more and it would die.... I checked the bulb numerous times and it seemed to have pressure. Then Later I remember that I had closed the vent on the gas tank so I opened it back up.... even after an 8 hr break and with the vent opened same issue, would die when throttled up..... I should also mentioned that in neutral if I choked up a bit it didnt seem to have any problems.
Got it home and checked the plugs and all 3 appeared very sooty and black all around, per the manual this is due to lack of heat?? So I replaced the plugs hooked up the muffs and started it in the drive, INSTANTLY started better than ever, sounded better and when throttled up did not die... So I figured what the hell problem solved.... WRONG....
Took it out 2 days later, launched boat went to open it up and I had better throttle than previously but I could almost instantly feel it losing power, within 5 min it was back to the initial condition, anything more than wake speed kills the engine....
Is it possible I caused a vacuum with Vent Closed on the Gas Tank? and does it take THAT LONG to recover?? Did Running it that low on Gas have an effect? It would seem to be a fuel issue but outside of the Vent Problem I am not sure where else too look besides the Spark Plugs..... Should I remove and clean the carbs?? Is this an issue with Flooding or LACK of fuel? Obviously replacing the plugs had an effect for the better albeit a very short fix.....
I am in Arizona and able to boat year round, winterizing is not much of a need here.
The batteries are also BRAND NEW less than 6 months old.....
Please Help!! I am coming into Prime FlatHead Season here!! Need My Boat!!
All motors will wind up on a hose in the driveway !!------This means very little.------------When was the waterpump last serviced ???-----------------Do a compression test and do a spark check ( each cylinder must jump a gap of 7/16" )-------------These are the first " no cost " steps in trouble shooting.
Sorry to Bump this but I need more help.
Update on the situation.
Compression is 130 across all 3 cylinders, Checked Spark on all 3 with an inline tester and Spark is there on all 3.
Replaced Spark Plugs.
Now I have NOT rebuilt the carbs yet.... I noticed when I was checking compression that the bottom cylinder (3?) was blowing out quite a bit of oil and gas mixture, I didnt get that from the top 2 cyliders when cranking the engine.... It appears that I am running very rich and possibly drowning the motor?
I am decent with a car Engine but ill be honest this is very new to me....
Is VRO still in use or does it have an earlier fuel pump ??---------------Sounds like you need to take apart and clean / inspect carburetors as well, and that is not hard to do.
no the Previous owner had bypassed the VRO.
I am extremely lucky, when I purchased the boat I was a complete Noob, he did not explain to me that he had bypassed it, When I filled the tank the second time after buying it (he had it filled for me) I did not add Oil because I Paid no attention to the fact that the VRO was bypassed, I ran the boat for probably less than 1/4 of a tank before I discovered this and added oil, SO when I say I am lucky, I am VERY lucky that I still have even compression....
I had every intention of rebuilding the carbs now....
It may be too late.--------------I would pull the cylinder head and look for scored cylinders !!-----------Sounds like the damage was done.It would only take about 5 minutes on straight gas.
