1986 Johnson 90 hp water leak ?
deebury
Is it normal to have water coming out of the mid-section around where the rubber mount covers are while having water running through the muffs ? Not alot but noticeable and I've not noticed it there before. If it's not supposed to be there what is likely to be wrong ? Also on another matter... if the 2 pin connector plug between the power pack and the stator has a poor connection is that likely to make the engine run as if it is only running on 2 cyl ? Thanks in advance.
