1986 Johnson 70HP Outboard Not Starting
Johnsonout
[FONT=&quot]After running well on the water all day the RPMs started to flutter down a bit. I shook the gas tank and it sounded pretty low so I killed the engine and switched to the auxiliary one. Then the engine wouldn’t restart. It wouldn’t turn over at all or make a sound when the key was turned. (Definitely had the kill switch in place, definitely had it in neutral). The boat has an electric trim tilt system which was still working and the lights were still working so I was thinking the battery is likely okay. I will check the voltage of the battery and the voltage across the starter solenoid because it sounds like that is the most likely culprit but I’m wondering why the engine started to die in the first place because the gas really didn’t end up being THAT low. I was able to pull start it and run it for a few more minutes until the engine started to die again and then shut off. Does anyone know what this might be? I’d really appreciate any and all input/advice.[/FONT]
Welcome to The Forum. Does it have VRO, if so, is it working? This doesn't sound good to me. Have you ever used ethanol fuel? VRO units were modified in 86 because of problems with the earlier units.....ethanol can still kill 'em, however.
