"i just bought 1986 70 hp vro
"i just bought 1986 70 hp vro johnson with remote controls. ran fine in driveway with water ears. compression reads 100 through all cyl. when i went to ramp to launch, motor stalled when shifted forward or reverse. it starts right up and idles nice in neutral, about 1200rpm. looked around , found some minor fuel leaks, replaced all fuel lines from tank outlet to carbs, including the primer ball, still stalls when i shift, if i push right through low speed in gear, it runs fine at high speed, but when throttled back , stalls at low speed in gear. did linc/sync procedure as described in servive manual, never touched wot timing advance, but dont rally get it. if i set cam follower at throttle plate as described in book for idle timing, then check timing, to adjust timing, you are moving throttle plate past center of cam follower. i think i am missing something, it seems that to get this right, you are changing your earlier settings. if i raise idle screw, idle will be to high for safe shift. when i look at cable movement, throttle does not advance until about 1/3 of travel through forward range at the control box, is this right. my yamaha throttle advances as soon as i click into forward gear. one other thing with the fuel filter, it does not stay full to the line when idling, it can hardly keep a 1/2in or so in the bottom, if i pump ball it fills up, but runs right back down. any thoughts or help would be greatly appreciated. thanks"
