Throbbin Rods
I am working on my son's boat and running into an issue. It is a 1986 Johnson 40hp. Motor used to run perfect but sat for 5 years. I have cleaned the carbs 5 times. Motor will run perfect until about half throttle. Beyond that it will surge, revving up and dropping back. In addition the low oil alarm goes off the entire time the motor is running in the water. The motor has had the VRO removed and runs on pre mix, not something I did. The wiring harness from the fuel pump has 4 wires. My understanding is that the purple wire is the power feed to the alarm horn for all conditions so I don't want to disconnect that. Motor has a new impeller, pees water as it should and I can lay my hand on it for an extended period of time while it's running. I am wondering if the motor might have gone into safe mode with the VRO removed and that might be the problem with running at high speed? I am just about to pull the carbs again for a sixth cleaning to ensure the high speed jets are clear. I would appreciate any thoughts or suggestions anyone might have.
Thanks,
Bill
Thanks,
Bill
