1986 j110tlcdc shift rod height and adjustment
Rangerjoe2
Hi guys,
The lower unit on our 1986 Johnson 110 hp j110tlcdc pretty much ate itself last summer. We replaced the lower unit with a new on that uses the two piece drive shift. I talked with one of our marine techs and he gave me a shift rod height of 21 27/32 in neutral but it won't adjust down that far. Am I doing something wrong? Also, which direction should the top face, to the rear? Thanks in advance.
Joe
Correct dimension.----Are you adjusting for this dimension with it in neutral ?----Post a picture of the top of your shift rod.
He just called me back. He said he gave me wrong year. It's 22 1/16 with the bend facing forward. Texted me a pic of the page in the repair manual. Thanks.
I just looked up the part number for this shift rod. It's 332120. Another site lists this rod at 30 3/4 inches. The rod I have is the same length.
I tracked down a similar issue. If the measurement is 21 27/32" and your current shift rod will not thread down to that height you have only 2 options. 1) have a machine shop cut, turn, and thread the rod you have to the correct length.
2) Spend the money and buy the correct length shift rod.
http://www.marineengine.com/newparts/part_details.php?pnum=OMC0332120
In my case, I found a previous owner installed a lower unit from a newer 150 that used a longer shift rod. The simplest solution was just to get the correct rod for my motor and it made everything a snap.
KJ
That's the rod I have. I ordered the repair manual. I have my own home machine shop so modification is not a problem. I chased the threads already and extended them a bit. I didn't want to go crazy yet. The part number is 332120 which is the same one you posted. That rod measures the same as mine at 30 3/4 inches. It's the correct lower unit for this motor as well. Kinda baffled.
