"help!!
the battery was only
"help!!
the battery was only 12 volts when i tested the motor running, started out at 13 volts, then it dropped. when i disconnect the battery the engine dies.
i see the purple wire is for the generator (?) and the only wires connected to the battery, are the main + - to motor and black and red to the switch. i bought the boat used, and it looks like the harness goes to the switch. so where does the battery charge? why does the motor die when i disconnect the battery?
i know i should get a manual, but cant locate a oem. seems like the only ones around are the clymer
"help!!
