Tuesday took it out to run some tests on the charging system. Ran up and down the water for more than an hour wide open throttle. Loaded it up went home fairly pleased with the way it ran. Took it out Wednesday and for the first hour ran great and then after sitting and fishing a bit, it started hard and then vibration in the steering though I bent the prop checked it and no problems. Could not get full power after that about 5 mph is all it would muster limped it home and parked it.
Is there anything that would make it slip timing? Would fowling a plug ? It felt like only three of the four cylinders were firing during that period.
