Back firing at idle… it starts and runs fine for the first 30sec or so but then starts back firing.
I don’t know what else it can be but timing: there must be a base timing setting.?
This is a new motor to me, I have know idea what’s been touched.
I’ve checked:
Seals, cracks, reed valves, hoses, carbs, TDC setting,
Ohms tested:
Trigger sensor @ 42 but swapped any, charge coil @ 569, both within spec.
I’ve changed:
Plugs, plug wires, coils, cdi, trigger sensor.
I’m just thinking back and believe my original idle timing was at 12btdc… I think your base timing should be around 4deg atdc and 28deg btdc full throttle….
Is that correct.?
