"Hi All,
I've been trying
"Hi All,
I've been trying to fix this motor on and off now for over 1 year with on/off success. Its been to many mechanics who have charge me a lot of money with minimal improvement. Decided to pull heads, open water jackets and find problem for myself.
I now believe the problem is actually in the water pump. I have attached bilge pump to copper tube with lower leg removed and get great water flow through the heads. With leg on flow is nill to minimal. Pump is NEW!. Looking in the discharge of the pump I can see the grease stain from where the copper tube sits when lower leg is assembled. It appears very low to the point where it may be bottoming out on the pump base plate, hence limiting the water entering the tube. Is this possible? has anyone seen this before? what is the fix? I hoping it could be this simple as I've spent considerable money and time on this engine now.
Thanks in advance
cheers
rr"
I've been trying
"Hi All,
Thanks in advance
cheers
rr"
