Hi folks, my usual starting routine is failing. I lift the (OMC control) fast idle lever high and the battery really struggles to turn the engine over (or crank as some people say). To the extent that there's no chance of it firing. I thought my battery was dying.
By chance, I tried to start it with the fast idle lever down, and it started to turn over normally! So I raised the lever once it was turning over and push in the key to give it some juice and then it fires and runs as well as it ever did.
This is recurring so not just a one off situation with a weak battery or something.
I don't understand why the battery would be able to turn it over fine with the lever down but not with it up. Is there some difference in terms of compression that makes it harder to crank?
Many thanks for any help!
