Just bought this motor on Crai
Just bought this motor on Craig's List. Of course no owners manuel. I mixed up a 50 to 1 - 2 cyle oil just to try it out. Not sure if this is right for the engine as it seems to smoke a bit. So what is the correct mix? The fresh water pump id putting out a real good pee stream but the exhaust just spits drops of water even after running in my garbage can 20 min or longer. Also is it normal to have smoke coming from under the motor cover too? Thinking I may have an exhaust leak under there somewhere. Tommorrow I will put it on the sailboat and try in the marina.
Thanks in advance for any input. Chuck.
