1986 evinrude 120hp vro
"try the old 2x4 trick ,jam th
"try the old 2x4 trick ,jam the prop with the wood,and get a good socket on the flywheel and crank,if the prop shaft turns without the prop its spun. or just mark it with a good paint marker and take it for a ride if the lines dont match its spinning."
"I have the same engine, I jus
"I have the same engine, I just posted and wondered if you can help with my query. Thanx, Hope your problem is fixed."
