1986 evinrude 120hp vro
"When the oil in the tank is l
"When the oil in the tank is low you will get a single beep every 20 sec's to warn you, a intermittant beep is the vro not pumping oil and a constant alarm is over heat"
"'now that is the safety s
"'now that is the safety switch right
so when the oil gets too low it shuts the motor down'
There is no safety switch 'shutting down'. The low oil alarm is just an indicator/reminder and does nothing to the engine. The NO OIL sets off the rpm limiter, but does not shut down the engine. Learn the different alarm signals.
Temp: Constant (SLOW)
No Oil: Short every 3-5 sec (SLOW)
Low Ol: Short every 30 sec."
