Good morning
I recently picked up a discarded DT4 2stroke. Cleaned out the carb and gas tank, replaced the fuel lines and got her started. The motor will only idle if the choke is partially engaged. Once I open the choke all the way she sputters and stalls. There is a screw with a spring on the side of the fuel bowl. Is this an idle mixture screw? It was found closed completely.
Thanks in advance
Jim
Thanks in advance
Jim
