1986 Crusader 454 electronic ignition conversion problem
Hi all,
I converted my port RH engine to electronic ignition using the complete Sierra conversion kit (includes the entire distributor) and followed the instructions.
I removed the ballast resistor, timed at the flywheel 10° marks at 650 rpms and used the included timing tool with a conventional timing light.
Engine idles fine, runs well at low speed, the problem arises around 1900 rpms, engine sputters and backfires, but when I push the throttle through it snaps out of it around 2300 rpms then runs fine from there upwards. Same thing decelerating, sputters around 2300-1900, then fine.
There are also moments when the rpms will shoot up/down disproportionately to throttle adjustment up and down (never did this prior)
Engine never behaved this when it was a breaker point system.
I called Sierra they sent me a whole new kit, new one is doing same thing.
I suspect there is something going on with the timing advance on this aftermarket product and maybe this isn't a good fit for my engine.
At this point I'm considering ripping it out and going back to points and breakers. I need to get this squared away because the other engine needs updating and don't want to install another problem system on that side.
Thanks for your input.
Assuming the Sierra kit you used is the Delco EST clone, there's not much to do assuming the issue is the distributor...I think the best approach to installing the EST systems is to set the timing so that the engine sees full advance at 3500 RPM and then live with the timing at idle and midrange...the timing adjustment is 'in the module' and is not adjustable and far from optimum.
The only other thing to check is that the IGN lead to the coil provides a solid B+ when the engine is running...sometimes the factory crimped wires aren't done well..
Junk that sierra kit, and switch to a Pertronix or DUI distributor.
Sierra products suck, IMO, they're all rebranded, mostly Chinese junk. I'm not particularly fond of the Delco est distributor either. It's not bad, but as you're experiencing here, the timing and timing curve kind of sucks.
I checked mine with a light and my timing is very inconsistent, it flutters around 2-3 degrees constantly. Without moving the distributor or timing light, the timing, at times (geneally at idle), will jump around like a jackrabbit. I'm guessing it's the computer and distributor constantly "talking" and trying to make adjustments.
I hate it.
The ESTs, in stand alone mode, have a very steep timing curve and exhibit similar behavior at idle and off idle...
Mako, any idea what would cause the timing light to go nuts (bounce all around 3-5 degees) at idle with an EST distributor. Doesn't seem like the gun is reading right, but it's a rock-solid $300+ snapon timing light, that works well in every other instance. Even when the engine is in timing mode, the mark is all over the place. Engine is running smooth as glass at idle, but it sure seems odd that the EST distributor is flopping timing all over the place.
Hi,
I have a similar if not identical Snap On light.
I also have a Delco EST set up in my boat.
Go to the INC button and give the light +1 degree.
That will often help stabilize the the reading (flash) at the crank.
As Mark mentioned, the EST has a very steep adv. curve.
You may want to check your timing chain for excessive slack if the procedure does not work.
Good Luck
Jon Allen
Guys, i'm new here and would like to swap out my old distributors on my 1990 crusader 454s. i saw a few EIs around 200.00. what all would be involved with a swap out. thanks
are you looking to swap the entire distributor or just ditch the points in favor of a breakerless subsystem?
you have to read the instructions for the new parts to get all of the details...The ballast resistor may/may not need to be removed....and usually the new units will have coils and plug wires as well...swap the distributors - add the extras and then set the timing...
is there a preference on brands or kits that are recommended. i was looking at the A-Team Performance Marine HEI Electronic Distributor 65K Coil Compatible with 350 454 V8 Mercruiser OMC 5.0 5.7 7.4, since its only 200. bucks just confusing when one is 200 and another is 600. and the descriptions are alike.
typically, you get what you pay for...i did a quick search as I have never heard of them...and I didn't see any details that gave me a warm and happy...nothing on warranty default timing curve, or adjustment of the timing curve....
Back when Mallory was a high quality producer, you could get a YLM624 and pretty much not have to worry...Sadly what is sold today isn't the same product from the good old days.
A lot of people opt for the EST kits...I don't like them in the stand-alone configuration as the timing curve is steep and non-adjustable.
Probably the upper end of the product line is the DUI marine distributors...they will dial in the mechanical advance before shipping it out...back when COVID was screwing things up, they were backlogged ~ 6 weeks...hopefully they have recovered. Their only drawback is the product has a profile similar to the GM HEI's of the 1980's, which is a taller than stock cap...some installations are tight on vertical clearance...
I have a Prestolite points distributor with mechanical advance on my old 1988 Chevrolet/OMC 4.3. I have thought several times of changing to an electronic distributor but keep coming back to the reality that on a boat that only gets used about 50 hrs a season the points just don’t wear that fast and I get at least 6-7 seasons before they might need replacement. I know most people hate dealing with points but over the 20+ years I’ve had this boat they have not been a chronic problem. And I can easily check the advance with an old fashioned timing light to see it it’s still in spec. When the parts were still available I bought spare springs; point’s & condenser are readily available. So at the start of each season I check em to see if they are gettin burned. If not I put a little cam lube on the dist cam, oil the wick in the shaft that lubes the flyweights under the points plate then replace the cap & rotor & hook up the dwell meter. Start up & check dwell & timing. If all in spec then fine if not minor adjustments are auto shop 101 circa 1970!
