1986 classic fifty 45 hp
wellfaremotor
hello iam Jason and this fourm has been very helpful in the past when i needed it so here i go again, I am changing the stator and trigger this weeken, when i pull the flywheel and change the stator and trigger do i need to do anything special when puting the flywheel back on, not to throw the timming off, or do I have check the timming anyway since Iam taking the flywheel off, also how do i time a motor if need be. :confused::confused:
It will still need to be re-timed. I prefer a timing light to do this right. Remove the cam arm from the top carb (one screw) so you can hold her wide open safely.
Jeff
