Gentlemen I could sure use some advice, replaced the filler hose,changed oil,added gas line antifreeze,went to start the motor and it ran fine with water muffs and ran well for a good 5-10min.
Stalled,checked filter/ seperator,emptied two or three times,checked filter at carb cleaned and lots of fuel there.
My question is I do not hear any spray of gas now when I put in full speed. If I put a bit of gas in the two barrel carb it will run for a few seconds.
It's a 305ci 86 motor.Tapped lightly on the fuel bowl but no change.I can't understand why it would run for a decent time and than stop. Is there a accelerator pump or something that feeds gas in after idle? Thanks for any help.
