When I try to start my 1986 90HP VRO after it has been running for awhile it is hard to get going. Cold starting is fine, I pump the ball a few times (which does not get hard) choke it pull the control to high idle and it fires right up. It warms up fine. Sometimes when I go to put it in gear, it stalls but it still starts right up and then when put in gear runs fine. It idles good a low rpm when I get to where I am going. Then after shutting it down and fishing for awhile I try to start it by turning the key it turns over and over but will not fire. When it finally does fire, it will not rev up by bringing the high idle lever up (the lever is right up and it barely turns 1000-1500 rpm. I have tried different things when starting it warm like priming the line again, choking it and just turning the key but it still does the same thing, no firing right away ( I have to crank it over and over and over to get it to fire) then when it does fire no RPM out of it? Any thoughts on what is making it do this? BTW the plugs are new and are the correct type, and they have a nice color to them.
