1986 9.9 Johnson 2 stroke
MitchGeorgia
I went out to flush my johnson today , and it is having trouble stayin running, so when it cuts off it want crank until you prime the bulb again so what should i try to do ...would it be just bad gas, or the gas in the tank it low but it is anough for just crankin i would imagine. the gas is over the gas tube so it shouldn't be that.and the carbs have been redone on the motor, i noticed the last time i ran it , it was cutting out alittle and it would just die, then had to prime and re crank it and run it like that, then it quit for a while and today it went back to it...what do yall think i should check or do...thanks..mitch
Turn the idle mixture screw CCW 1/2 turn and see if it idles better. Check the fuel filter(s). Vent screw open? Old gas is trash. Fuel pump may need rebuilt.
