TigerShark1
Idles fine but after it been running for awhile it will occasionally stall out when engaged and running just above idle. You can generally put it back in neutral increase the rpm's take it back down to idle and then engage again
Replaced fuel pump, replaced most fuel lines, new plugs, cleaned cards, replace primer bulb, and inline fuel filters.
The idle is set at about 1200 rpm's which seems a bit high.
Any and all input is appreciated.
Joe
Joe
