1986 60hp johson lower knock watery oil
aaron
"i have a 60hp johnson and a c
"i have a 60hp johnson and a couple weeks ago i took the boat out and a chuck got broken off the prop and it was running rough so i got a new prop and discovered water in the oil.took the boat out today ran good at first,after about 20 minutes it started making a knocking noise from the lower unit, it would only do it,in gear under power.sitting at idle it sounded fine.still getting water in oil. i have located a seal kit and have not pressurized it yet till i figure out the knock thank you"
"If you're sure that knock
"If you're sure that knock emits from the lower unit, the proper thing to do is to dismantle it completely for inspection to find the faulty component(s)."
