3 cylinder. Melted the electrode of a loose spark plug last week. I pulled the exhaust port and looked, damage not bad in cylinder or piston. Harbor freight compression meter reads 80 lbs on all cylinders with motor cold, all plugs out, throttle at start position. Several checks. Took the boat out yesterday. To start engine, I choke it and hit the starter till it fires(approx 5 - 7 revolutions), throttle at idle/start position. Will not start with choke(enrichment) on. Take choke off and hit starter, cranks it 2-5 revolutions. Runs great at WOT or any speed above idle. When it has been sitting for a day it will crank and idle after start, shift, back away from dock, ease 1/4 mile through no-wake area, all really well. Comes to speed and get to fishing hole, park and shut down.
This is the problem: When I start it after the above, it will die unless I slam the throttle open fast. Starting procedure is the same as cold start unless I have just shut it down moments before; give it 15 minutes and if I do not snatch it wide open it dies. Occasionally it fails and dies after I snatch it wide open, doesn't seem to catch up. If I get 5 seconds of run it will continue, will idle fine. Idle speed adjust screws: In the water, warmed up, tighten till it staggers. Then loosen till it staggers. Then get 1/2 way between those two settings, then loosen 1/4 turn. Any ideas? Help! Immediately after I shut down, it will start right back up with no choke and run fine.
