"I have a 1986 Evinrude 50hp E
"I have a 1986 Evinrude 50hp E50TLCDE. This was recently switched from VRO to the conventional fuel pump. The problem I'm having is it won't idle. If I push the primer it picks up speed. I've got it figured out that the top carb is not feeding fuel through the low speed passages. Both carbs have new kits and floats and are clean as a whistle with no corrosion of any kind. I have swapped the carbs and the problem follows the carb. Everything in the carb looks good, clean and nothing plugged. I looked at the reed pedals, there is a little clearence in these maybe .005"-.010" no more. This one has me stumped and help is greatly appreciated."
