Good evening,
Been browsing forum but found no specific examples of the problem I have... so here I am!
Have a Volvo Penta 5.7 with a 290 z drive from circa 1986.
Bought the boat fairly recently and needed some work, new floor, interior seats etc. Engine appeared some what OK if not grubby.
Anyway, I took the boat out for the first time and ended up being towed home. Engine was ok for about 45 minutes, then bogged down and would not idle properly at all. Once running, it wouldnt get about 2000 rpm, then would just stall.
Anyway, to cut a long and arduous story slightly shorter, I have completed Following in no particular order
New fuel pump
New fuel Lines
Removed any restrictions in fuel line
New spark plugs
new Oil Filter + OIl
Cleaned and decrudded dstributer cap + cables but not replaced
Cleaned Carb and readjusted
Boat went back out on the water after the initial problem and was seemingly OK, but after about 40 minutes of slow running through and estuary and back went to throttle up and it just wouldn't....
Gets to about 2000rpm and no further, just bogs down, coughs splutters and gives some interesting backfires!
Had a tinker in the shop, and it runs perfectly idles great with around 18g or mercury at Idle at around 900rpm. Picks up fine under no load and revs great. A soon as you load the boat, the problems occur. Feels like a fuel starvation issue, but I have adjusted everything and fuel delivery at carb is more than substantial.
I'm no major expert with holley carbs, but believe I have this setup correctly given what I have read around the web. I believe Its a 4160 based carb list 80309 if anyone is interested.
I'm fairly certain its a carb issue, given that nothing else has otherwise changed, Dizzy cap is in the same place and does not move so ignition timing is ok although I haven't actually checked the actual timing, vacuum advance moves correctly. I haven't had the guts of the distributor apart yet but have no real reason to suspect this, the whole things is integral as far as I can see as there is no coil. I have a vacuum gauge that I fitted to the boat, under WOT the vacuum drops as expected to next to nothing, the boat will not pick up under partial throttle and any sort of gentle throttle increment its just bogs at around 2000rpm The gauge is otherwise stable, (apart from the occasional misfire).
Would appreciate some advice if anybody has any ideas!
Jody
New fuel pump
New fuel Lines
New spark plugs
Jody
