Hi all I hope you gyus and gals can help
I have a thunderbolt iv ignition problems with my (new to me)1986 5.0L carberated 8cyl merccruiser alpha one thunder bolt IV ignition.
This is what I know, Coil is good, Ignition sensor in distributor is new. The white/green wire from the ignition amplifier plug on the risor going to the ignition sensor in the distribtor was unseated and pulled slightly from the plug. I removed the plug from the ignition amplifier and redid them all to ensure a positive contact with male connectors in the igniton amplifier and she fired up beautifully. Now I could be boating for an hour or maybe 2 then POW. No spark. I'll shake the plug going into the ignition amplifier and cross my fingers and she might fire up if she doesn't Ill start to steam home on my kicker and try again to start the main and she will fire up after about 3 or four tries.
I'm fustared with situation and would like to replace the ignition amplifier and wires. I need to buy a few parts but am not sure what to buy. I'm not sure if my motor is GM or ford, big block or small block. or maybe replace the whole dam thing with something like this:
http://bpi.ebasicpower.com/p/MALYLM512DV/Distributor+Ford+V8+302+MBI+RH
It says Distributor Ford V8 302 MBI RH. I'm not sue if this part would fit my motor and would like help in identifying what parts I would need.
Any help appreciated. Thx
