guido2
This was running good last season. First thing this season had water contaminated fuel run into it. Owner had bad fuel cap on his pontoon boat. I replaced fuel tank and hose with fresh fuel also new spark plugs. Forced fresh fuel through carbs while engine was tilted and then started ok. Running on only top 2 cyls. Spark very strong on bottom cyls but no power and will not idle. Good compression on bottom 2 cyls but only the #3 cyl showing a wet plug with fuel mix. #4 cyl drier?? Don't see why because lower carb seems to be providing fuel. Any ideas? Thanks, Guido
