"Having an issue with the WOT
"Having an issue with the WOT on a 1986 11m Trojan. The boat was purchased five years ago with 450 hours. When the boat was purchased it had the wrong props that would only let the boat max at 3200 RPM (The owners manual stated the max RPM was 4400)Through extensive research into what the correct props were for the boat we replace them with 4 blade 24 x 24 blades. The boat maxed out at 4400 RPM. Several years later the boat will only max out at about 3800 RPM. A couple of notes, one the Distributors have been changed since the original purchase of the boat to electronic, two the engines know have approximately 800 hours ( and run like new). I have checked to make sure the secondaries are open all the way at WOT, which they are. Any suggestions would be appriciated."
