Hi Guys,
Have a 1986 4.3 that I am having trouble starting. Had problems starting at times last season. Installed a new starter last week. Put batteries in boat and tryed to start, it would not crank. Both batteries are old but reading around 12.4 volts. I also installed a new slave solenoid.When I try to start voltage on the slave solenoid is around 8 volts. I put an amp meter on the battery cable and it does not show any amp reading when trying to start. Do you think I have two bad batteries even though they show over 12 volts.The trim pump, blower etc. seem to work with out any problem. Thanks for any help given.
