Hi everyone, I'm trying to test the stator and trigger using a multimeter. Via a manual and online resources I've found that the specs are:
STATOR:
Black yellow(LS) to ground=3200-3800 ohms
Black white(HS) to ground=225-300 ohm
TRIGGER:
Brown yellow to brown white=750-1400 ohms
Problem is, there are many of these colored wires and it has me very, very confused. Im not sure which black and yellow wire to test between ground and I'm not sure how to disconnect the white and black wire from the switch box for testing? All black and yellow connections get nothing except for the very top right connection is about 0-10 ohms between ground. What would be a good ground point? I havent tested the black and white wire becuase I'm not sure how to disconnect it. As far as the trigger goes I'm unsure of which brown yellow and brown white pair to test between, becuase there are 2 of each color wire on the right side of the box. I'm sorry if this is all confusing or stupid questions, any help would be very appreciated. I will post pics below. Thanks
STATOR:
TRIGGER:
