Got myself into a bit of a pickle.Started the boat after assembling the motor after winter shut down.Good oil pressure,water flow,temp,voltage etc.after about20 min shut motor down to change oil and filter.Drained oil,put wrench on oil filter ,would not move.Filter started to twist and leak but not turning off.Pounded screw driver through filter and tried turning.No luck,now i'm basicly down to the top of the filter only where when I reach under I can feel the inner filter thread and the 7 holes on the top of the filter.I'm not sure if it's the rubber ring or the thread holding it on.All the body is off the filter,twisted and bent.How can I remove the remaining part of the filter so I can install the new filter(Qs30).thanks homerl.
