Hi, 1986 Volvo Aq 151 with 290 single prop drive.
I drained the outdrive lube and it was black and smelly. Leakdown test was perfect(as expected).
I know black usually means worn and gear issues so I sieved the drained oil through a coffee filter. Some grit was found and two small metal chips about a 1/3 the size of a small mouse dropping.
Am I correct that the drive is on the way out?
What typically croaks when running and can you generally make it back in.
I am working on finding a reasonably priced used drive.
In the meantime I'd like to nurse my existing drive along for a little bit. It's not making any obvious noises. It is currently LH rotation.
I have a RH prop and thought of switching it to RH rotation to use different gears(not sure how many are involved), but is some is better than none?
Any help would be appreciated,
Mike D.
Mike D.
