1986 28 hp Johnson Water pump replacement
rbowen
I am getting ready to drop th
I am getting ready to drop this lower unit to replace the water pump since it stopped "peeing" sunday. I checked the hose's to the pee hole just in case it was clogged and no water @ all. The question I have is there any particulars I need to be aware with this change. Mostly the shifter connection between the lower unit and the top end. How are these disconnected? Any advice will be appriciated. I changed one in a 25 yama saturday and had some trouble with the shifter linkage and want to avoid that proble on this one.
I'm not sure how the shif
I'm not sure how the shifter disconnects but the lower unit is held on with just 4 bolts
