OK Guys.. I am throwing a hail mary on this one. Hopefully someone can help. I am having a engine knock when the motor is under load. I can idle at 1000 to 2000 all day without a problem. I can get up on plane without a problem even run at higher RPM's fine. When I go to take a corner, I hear a loud knock. I was told so many things it could be. From "LEAN FUEL KNOCK?" to the engine is shot.. I did have the pump from the external oil tank replaced right before this started. One other point, I did have older fuel in the tank when this issue started....I look forward to hearing the comments on this.
Thanks.
Thanks.
