i ran a compression test on all 3 cylinders and #1 and #2 were about 117psi and #3 was about 122psi. does this seem right? does anyone have the compression specs for these motors? im also considering running a leak-down test on them as well.
i ran the test because when i start the motor i let it idle for 15secs, then put it into gear and give it gas and it just sputters and dies. it does this about 7 8 times then it finally wants to start going. it may be a carb issue but someone said it may be compression related. can anyone shed some light on this issue? any help would be appreciated!
