1985 OMC
K
kid
Guest
As most of know I have been wo
As most of know I have been working on this boat all summer and still am. Now I need more help again. When I hook the hose & muffs to the outdrive and start engine rev it up a bit then I get water comming from the supply hose when I take it off the T houseing. Thats a good thing. Here is the but part. I also had a bit of water spitting out where the supply hose goes on. So the water pump on thr engine is working. The Dam thing still went up to around 200 D. What could it be now?
My boat runs hotter on the muf
My boat runs hotter on the muffs as well.When I put it in the water it always stays at 165.I find the muffs are only good for short running times.good luck
Are you using a normal size ho
Are you using a normal size hose? I was using a small diameter coil hose one time and it wasn't supplying enough flow.
