1985 OMC water pump
K
kid
Guest
I have recived the water pump
I have recived the water pump kit. There are all kinds of O rings that came with it. Now I need help putting it all together. Where do all the O rings go. Dose someone have a drawing of how it goes together. The guy that took it apart is not around so I am on my own. Please help.
"This should give You an idea:
Thanks Morten This is way cool
Thanks Morten This is way cool. Just one more thing. how do you get the shifter cable out of the lower unit?
"You will have to disconnect i
"You will have to disconnect it inside the transom first, then pull it out. Be careful, it is expensive and not repairable!!!!"
"Wow, that BRP site is awesome
"Wow, that BRP site is awesome, right down to the correct silver paint I would need!"
"Rod...just because you can se
"Rod...just because you can see the PN's in there, actually finding the parts is another story and some are getting harder to find as we speak!"
