weterthebetter
I had a Topic on can you repace engine without pulling the out drive.
Thank you for the replies.
Now may not have to pull engine,
I gave the cooling system a leak test of 23 lbs of air, the results was no leakage.
The puzzling thing is the oil is milky. I changed the oil and filter twice.
The engine runs great, but how is the water get in the oil??
The only cracks I found was each exhaust manifolds has a crack along the bottom about 3-4 " long.
Any body have any input on this??
I was going to do a Compression test to check each cylinder for PSI but got snowed out.
I let the cooling system with 23 lbs of PSI for one hour, no loss if PSI.
Thank you
Thank you
