1985 OMC GM 4 cyl
K
kid
Guest
I have a 1895 OMC 4 cyl. that
I have a 1895 OMC 4 cyl. that is over heating with the garden hose hooked up. There is no water going through the motor even with the water pressure from the hose. Should there be ? Or dose this mean I need a new water pump.
"Ayuh,....
At the Very Leas
"Ayuh,....
At the Very Least you need a New raw water pump Impeller......"
Thanks for the come back. Coul
Thanks for the come back. Could you give me a ball park price.
"impeller is around $15 last
"impeller is around $15 last time I bought one, about $50 for the kit with the housing. 2.5 hours to install...."
Now for the hard part. If I ge
Now for the hard part. If I get the water pump kit dose it have all the gaskits I will need?
there are no gaskets - There i
there are no gaskets - There is 1 o-ring around the housing if you get the full kit - and will also come with new driveshaft grease seal- the manual calls for a non hardening permatex type sealant.
Do you know of someone around
Do you know of someone around Brampton that can fix this
"I'm in Lindsay, but no I
"I'm in Lindsay, but no I don't know anyone closer that I would trust. If you remove the drive yourself you can take it to TC Electronics and marine in Scarborough... you could call them- I don't think they work on boats there - just drives. they know what they're doing though."
"Hy Stat
Do you fix boats
"Hy Stat
Do you fix boats by change? If so would you like more work. If so how much ?
Please e-mail me at my e-mail address or at [email protected]"
